Vw techs? Need some help?
Old Jul 24, 2012 | 04:50 PM
Butch.'s Avatar
Butch.
Default Vw techs? Need some help?
I've got a vw phaeton 2005 3.0 v6 diesel with fault code p1545 throttle valve malfunction but there are 3 throttle valves 1 on each bank and another before the inlet splits into each bank any ideas?? Help!!
Old Jul 24, 2012 | 05:24 PM
Greasenuts's Avatar
Greasenuts
Hi, i would be tempted to say, if it was either of the flaps on the banks the code would suggest either "bank 1" or "bank 2"....
Im not a vw specific tech but that is fairly universal.
please dont take my word for this but it might be of some help....!
Old Jul 24, 2012 | 05:43 PM
markk's Avatar
markk
The simple way to detect which sender is at fault is to unplug it, see what codes are stored when you unplug each body, thats without me looking into your P code.
Old Jul 24, 2012 | 05:50 PM
Mark_'s Avatar
Mark_
Taken from Ross Tech..............
Possible Symptoms
Increased Idle Speed
Bucking at Load Change
Possible Causes
Throttle Body dirty
Throttle Body Wiring faulty
Throttle Body faulty
Possible Solutions
Clean Throttle Body
Check Throttle Body Wiring
Check Throttle Body
Special Notes
Use Meas. Blocks & Basic Setting for testing
When found in the NAR 2.0l TFSI: (BPY, CCTA and CBFA) check TSB 01-09-04 or 2018652 for a wiring repair at the Throttle Body.
See Throttle Body Alignment (TBA)
Category:
Fault Codes
Old Jul 24, 2012 | 07:51 PM
Butch.'s Avatar
Butch.
After in plugging each one found that is the first throttle body that's Knackered but least I know what to get now thanks for your help everyone!
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
