Small turbo Escort Cossie fan switch?
Old Jul 23, 2012 | 08:00 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Default Small turbo Escort Cossie fan switch?
Is the small turbo fan switch different to every other Cossie? my fans won't come in automatically, but work if you bridge the connection out?
It's on a std rad at the moment, with a green colour switch, fans work when you turn the Aircon on, but not when the car gets hot. Corner of the rad is getting hot so should get it warm enough to switch.
Anyone got the part number please?
Old Jul 23, 2012 | 09:11 AM
Brendan's Avatar
Brendan
struggling with reality
test the fan switch in a cup of boiling water! that's what I do! it is very simple and it works! I am sure stu at MSD can sell you one and tell you where to get one if he can't!
Old Jul 23, 2012 | 09:14 AM
RWD_cossie_wil
The one fitted is brand new, with a green collar, I'm just wondering if the small turbo is a different item with different switching temps etc?
Old Jul 23, 2012 | 12:23 PM
martysmartie's Avatar
martysmartie
Has yours not got a four pin connector, as Escos has dual speed fans, and a four pin switch?
You have the two pin "uprated" switch, it should still work, but bear in mind it won't close until around 90° C.
Martin
Old Jul 23, 2012 | 12:24 PM
RWD_cossie_wil
I can't remeber will have to have a look tonight!
Old Jul 23, 2012 | 01:01 PM
Jeff Collision's Avatar
Jeff Collision
You need to rewire the plug, as it is very easy to do it. It would be fine, if you check your battery mode too.
Billy_RS
16
Oct 11, 2025 09:41 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
steerfromdarear
28
Jan 29, 2016 06:14 PM
Vincereese
Aug 16, 2015 06:38 PM
stickyslick
14
Aug 10, 2015 06:27 PM
