Ford Puma Discuss the Ford Puma here!
pls help rear lights :(
Old Jul 21, 2012 | 12:43 PM
RSTurboBird's Avatar
RSTurboBird
Default pls help rear lights :(
brake lights are working but all of a sudden dash lights and tail lights have stopped working
checkd fuses/relays
sprayed wd40 on the indicator stalk and the plugs as advised?
this hasnt fixed the problem
any advice of anything i cud try at home wud be great
thanx
Old Jul 21, 2012 | 12:44 PM
RichieST's Avatar
RichieST
When this happens it's usually the switch unit itself that has failed, so I'd try replacing it and seeing what happens.
Old Jul 21, 2012 | 12:48 PM
RSTurboBird
Thanku, u means the stalks right?
Old Jul 21, 2012 | 12:57 PM
RichieST's Avatar
RichieST
Yes that's it, I presume the puma has the twist bit on the indicator stalk?
Old Jul 21, 2012 | 01:01 PM
RSTurboBird
Yeah they are, wernt taken apart properly wen sprayed tho
Bailes1992
Sep 3, 2015 02:17 PM
mint_s2
Sep 2, 2015 08:58 AM
RsS2daz
Aug 14, 2015 05:26 AM
sridgett
15
Aug 3, 2015 07:26 PM
