Ford KA Discuss your Ford KA here!
Over-revving problem
Old Jul 21, 2012 | 08:13 AM
neilio82's Avatar
neilio82
Default Over-revving problem
Hi,my 2000 Ka has a problem with over-revving, which has got worse the past few days. basically when accelerating the engine can over-rev and take a while to "catch-up" with itself. the problem is much worse when going up hill or accelrating hard. been doing a fair bit of research on the tinterweb, and a lot of posts are reccomending disconnecting the battery for 30 mins, cleaning the ICV and TPS, the first two i'm going to have a crack at today, but i'm worried it might be the clutch slipping, as most of these posts ive read say the problem happens (over revving) when taking the foot of the clutch, whereas mine is definately during acceleration and a couple of times when coming to a stop.
Be intresting to know if anyone else has had the same problem and been able to do anything about it.
Thanks in advance.
Old Jul 21, 2012 | 10:15 AM
martysmartie's Avatar
martysmartie
Just re-read this, yes if the engine is revving and you are making little progress then yes your clutch is slipping, it will be worse when going up hills or during acceleration as well, another sign is if the clutch will only 'bite' right at the top of the pedal.
Martin
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
