2k rpm power loss st170
Old Jul 19, 2012 | 07:49 PM
seddo's Avatar
seddo
Default 2k rpm power loss st170
Alright guys has anybody came across this problem were the power surge from 1500 -2000 rpm has like dissappeared? The car just doesn't have the balls it did have.there's no missfires, fuel cuts, or low idle probs etc just loss the power an seem to use more throttle to get upto speed. Changed lambda sensor in past.
Old Jul 24, 2012 | 07:42 AM
seddo's Avatar
seddo
The car drives as if the choke was still activated or the ecu has not removed the limiter but it will go to the redline. Wish focus could see these faults a lot easier
Old Aug 10, 2012 | 01:15 PM
Sp3no's Avatar
Sp3no
You fitted an air filter recently? Sounds like heat soak.
Old Aug 11, 2012 | 08:12 AM
seddo's Avatar
seddo
an air filter was on the car when bought it but its a panel filter so cant be heat soak problem, not sure if its the maf
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
