any advantage with modern injectors in my 2.1ZT
Old Mar 3, 2005 | 10:49 PM
mrviper's Avatar
mrviper
Default any advantage with modern injectors in my 2.1ZT
i have some cosie injectors for my omex (omex can use high and low inpeadence)
but have been offerd some injectors (430cc) from a modern vauxhall 2.2 turbo and it has 4 jets
would thease gove better fuel econamy or power ?
Old Mar 4, 2005 | 01:29 AM
Project ST's Avatar
Project ST
What little I know about injectors (about > . < ) is that 4 pintles will give better atomisation than one or two so you should get a better burn.
430cc - about 400bhp potential? Only problem is they might not be compatible with the standard end-fed fuel rails...
Imvho you would be better running side-fed injectors as you can use the standard Zetec fuel rail (which are common as muck). Side feds aren't as common as end-feds though, so some hunting might be needed (iirc there's a couple of performance Jap cars that use suitable ones).
/al
Old Mar 4, 2005 | 04:40 PM
mrviper's Avatar
mrviper
thanks for the info mate il look in to it but i have already made a rail that works with the cosie yellow injectors i have laying around in my draw
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
