2010 ford focus rs leak
Old Jul 19, 2012 | 09:42 AM
Mgd's Avatar
Mgd
Angry 2010 ford focus rs leak
Hi All, Last week I noticed that the passenger side floor was wet, anyone else had this problem? Have taken it to dealership this morning and they are saying leaks are not covered under warranty and they will investigate, am now waiting for a phone call, any help much appreciated.
Thanks Mike
Old Aug 17, 2012 | 02:48 PM
R5FORD's Avatar
R5FORD
Thanks Mike
Yhep mine had this problem and all the carpet/underlay was replaced through Ford.. Its prob the same problem, theres an aircon drain off pipe which has probly not been connected properly.
Old Aug 17, 2012 | 03:18 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
if it's a fault caused by a defect on the vehicle then of course it's covered!!!
Old Oct 16, 2012 | 10:45 AM
Mgd's Avatar
Mgd
Well, third time back to garage and they have finally found the problem, crack in seal on bulkhead. They told me it would cost £300 to fix but they will charge me £200 as a good will gesture. I told them to fix it as I want it back ASAP. I am now looking for Head Office phone number to complain as I think it is a manufacturing defect. I want my money back.
Any help much appreciated
Thanks Mike
Old Dec 25, 2012 | 12:47 AM
atm's Avatar
atm
Its usually the common fault and nothing serious, the foam seal on the pollen filter cover (the n/s part of the scuttle panel) needs replacing regularly or this happens.. Water leaks in down the bulkhead wich soaks passenger side carpet. Foam seal cost about 3 quid..
Ford Focus RS Parts for Sale.
Aug 18, 2015 05:25 PM
taylora1409
Aug 12, 2015 12:06 PM
