OIL press gauge ??? help
Old Mar 3, 2005 | 09:45 PM
DOO's Avatar
DOO
Default OIL press gauge ??? help
Got an oil press gauge with a 1/4" adapter to fit onto the block somewhere am i right in thinking there are some 1/4" blanking pulgs fitted some where on the block for the union to fit into for the oil press gauge??
if not the i need to buy a T piece and fit it where the oil press switch goes??
Old Mar 3, 2005 | 09:50 PM
extra14's Avatar
extra14
Just use a T piece connected to the oil pressure switch.
Darren
Old Mar 3, 2005 | 10:12 PM
Skinz's Avatar
Skinz
Darren
I'll second that motion!
Old Mar 3, 2005 | 10:14 PM
SPADGE's Avatar
SPADGE
Mike R can supply the adaptor and yes it goes where your oil light switch is
Old Mar 3, 2005 | 10:26 PM
DOO's Avatar
DOO
T piece it is then
need one this weekend try local if not i will be in touch with mike
Old Mar 3, 2005 | 10:50 PM
CraigN's Avatar
CraigN
just replace the std oil pressure switch
i forgot on 4x4 the oil feed is on the other side of the block is it not ?
Old Mar 4, 2005 | 10:30 AM
Damo V's Avatar
Damo V
If you need one today/tommorow, try your local Pirtek mate, take the old oilswitch down and new bit to get correct thread etc.. Im 99% sure they will have it in stock
http://www.pirtek.co.uk/site/English/index.asp?lang=1
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
