Cossie 4x4 quick shift Q.
Old Mar 3, 2005 | 08:58 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Cossie 4x4 quick shift Q.
Can you get one that works with the standard gear lever ? I am thinking about getting one, but don't really want to have a "boy racer" stick/gear knob.
Old Mar 3, 2005 | 09:06 PM
Eagle's Avatar
Eagle
Super Moderator
boy racer
Old Mar 3, 2005 | 09:10 PM
SPADGE's Avatar
SPADGE
Don't bother they make little or no difference imo!
Old Mar 3, 2005 | 09:12 PM
frog's Avatar
frog
er no I want quickshift but no shiny knob (oooh errr missus).
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
yes u can rally design do them £39.50 plus vat also they shorten the mt's dredful throw worth having for that factor imo
Old Mar 3, 2005 | 09:14 PM
Eagle's Avatar
Eagle
Super Moderator
so one says yes......... one says no .... erm any other offers as i want one too
Old Mar 3, 2005 | 09:16 PM
SPADGE's Avatar
SPADGE
Fair enough but like i said they are shite! Been there and done it and the only one that made even the slightest amount of difference was the B+M jobbie which comes with the lever etc...but that was negligable.
Old Mar 3, 2005 | 09:17 PM
Rs Gus's Avatar
Rs Gus
and mine has snapped B&M
Old Mar 3, 2005 | 09:36 PM
frog's Avatar
frog
Are the 2wd and 4wd boxes that much different in terms of throw ?
Nat's 2wd with quickshift is significantly shorter.
Old Mar 3, 2005 | 09:38 PM
SPADGE's Avatar
SPADGE
Yes there is a vast difference between the throw on a 2wd box to a 4x4 one! You will never get it like a 2wd regardless of quick shifts etc..
Old Mar 3, 2005 | 09:39 PM
frog's Avatar
frog
Sorry spadge, that comment was meant for pete, but you snuck your post in there, I should have quoted him
Rs Gus's Avatar
Rs Gus
agree with spadge there 2wd is far nicer in std form without quickshift
Old Mar 3, 2005 | 09:41 PM
frog's Avatar
frog
Ah, ok, so that might just settle that then...
Old Mar 3, 2005 | 10:14 PM
jamesXXX's Avatar
jamesXXX
i cant fault my b&m quickshift, it is a massive improvement over standard, but a tw@t to fit when the gearbox is still in!!
Old Mar 3, 2005 | 10:16 PM
SPADGE's Avatar
SPADGE
Are you sure you didn't just convince yourself it was a massive improvement as you had just spent 150 odd quid and a day fitting it
Old Mar 3, 2005 | 10:23 PM
jamesXXX's Avatar
jamesXXX
no the other one was fooked, i had to take the ashtray out to get first gear!!
Old Mar 3, 2005 | 10:30 PM
SPADGE's Avatar
SPADGE
A lot of the time it is the bushes in the gear lever cradle thing that are fooked that leads to loads of play!
Old Mar 3, 2005 | 10:33 PM
rstoughy's Avatar
rstoughy
Got to agree with SPADGE on this one, Got a quickshift in my 4x4 and it made very little difference if any . I know for a fact if i ever bought another cossie with a standard box i would leave it as and wouldnt waste my money on one.
Old Mar 4, 2005 | 05:24 AM
Eagle's Avatar
Eagle
Super Moderator
made my mind up then
Old Mar 4, 2005 | 07:39 AM
frog's Avatar
frog
And mine too - shame really, the 2wd shift is so much shorter, kinda fancied that for mine...
jessie_rs
62
Aug 6, 2019 09:27 PM
Billy_RS
Sep 13, 2015 04:17 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
