Stainless Goodridge hoses, problem fitting (pic)
Old Jul 15, 2012 | 10:22 AM
Cossy Mike's Avatar
Cossy Mike
Default Stainless Goodridge hoses, problem fitting (pic)
I've gone to flare and form my brakes pipes on my Cosworth and the Goodridge hoses supplied done seem to fit
Am I doing something wrong here?
There not enough threads left for the Brake union. The nuts seem a bit thick, should they not be a shallow type?
Thanks!
Old Jul 17, 2012 | 02:20 PM
cameron2's Avatar
cameron2
If you take the washer off the top, does the fixed nut on the pipe sit in the mount/ hub?
Mine did on the rear.
Old Jul 17, 2012 | 03:23 PM
StephanCosworth's Avatar
StephanCosworth
loose the top washer.. The hexagonal part will fit into were the washer is covering it now. As far as I know there is also a some sort of hexagonal shape in the beam itself were it should fit in, at least at my car.
After that there is enough thread left!
Old Jul 17, 2012 | 03:26 PM
StephanCosworth
example...
Old Jul 17, 2012 | 06:05 PM
Cossy Mike's Avatar
Cossy Mike
Yeah it works on the bottom arm without washer on the top.
However, I have the same problem on the rest of the car. The longest hose that goes from the arm to the under body.
I've used thinner washers which does help but ultimately I need 'half nuts' and it'll be problem sorted.
Seriously P*****d off with Goodridge at this
Old Apr 3, 2015 | 05:58 PM
costina's Avatar
costina
Live long and prosper!!
Well Mike i have had 4 weeks of trying to sort suitable hoses for my saff with stainless ends. I have opened a can of worms. And even goodridge fucked up after making some on instruction from GGR. 12 ends 6 of which was zinc 6 stainless and the 2 caliper hoses too short.
How the hell they are tuv approved is beyond me.
Old Apr 3, 2015 | 07:59 PM
Cossy Mike's Avatar
Cossy Mike
I got mine sorted in the end
I binned everything that came with them and bought stainless washers and half nut's locally.
Burton didn't want to know, they said they would complain on my behalf as I am the only customer they have had that had bought full stainless lines with stainless fittings for a cossy. Burton offered me 20% discount on my next order which I took them up on after spending another £450 on Samco stuff.
tbh it wasn't worth the hassle of buying them, they cost me around £120. I'll be changing them again soon when I go AP's.
They're on now, however I never had an issue with length?
Old Apr 3, 2015 | 08:37 PM
costina's Avatar
costina
Well i am still waiting GGR have been great Darren and Graham Goode. Graham is annoyed at his suppliers hence why goodridge have been asked to make some up for me but they are wrong too lol. The initial set supplied by ggr had stainless ends but were machined to take both types of brake flare which didnt fit. So i will see what happens this coming week.
If no joy i will purchase a set of HEL lines in the hope they are correct.
Paul
Old Apr 4, 2015 | 06:18 AM
Cossy Mike's Avatar
Cossy Mike
Paul
Let me know how you get on, who supply's the HEL lines?
Old Apr 4, 2015 | 07:30 AM
cossie330's Avatar
cossie330
I went for hel lines on mine, they fitted perfect, came with stainless half nuts too
Old Apr 4, 2015 | 08:38 AM
costina's Avatar
costina
Mike,i have seen them on ebay.
Old Apr 4, 2015 | 08:40 AM
costina's Avatar
costina
Thats good news car was ment to be done last week lol.
Do you remember where you purchased them from?
Thanks
Paul
Old Apr 4, 2015 | 12:14 PM
costina's Avatar
costina
But on another thread you said the ends are different?and asked what size pipe u needed. I have just ordered some hel lines and i have a horrible feeling they will be the same as the first lot from GGR. With the poxy double ended fittings. Which would then mean my new hard lines i have made and painted green will.be no fucking good.
Old Apr 4, 2015 | 02:13 PM
cozzy jeff's Avatar
cozzy jeff
mine came from woodford garage,fronts to suit AP'S,perfect fit.
Old Apr 4, 2015 | 04:33 PM
costina's Avatar
costina
Look nice but still only zinc plated ends.
Old Apr 5, 2015 | 11:06 AM
Paul_RS's Avatar
Paul_RS
The problem is always the nuts being too fat. Fitted loads over the years and most have had the wrong nuts supplied. We get all ours made locally now - Stainless fittings and crimped ends as IMO the screwed together fittings are crap.
Old Apr 5, 2015 | 11:23 AM
costina's Avatar
costina
never had a prob with nuts always had half nuts supplied. Once this saga is over i will post pics.
Old Apr 5, 2015 | 12:08 PM
cossie330's Avatar
cossie330
Youre right i did lol, i some how managed to fit the ones from chassis to rear beam onto the fronts but once i fitted the right ones to the right places they were spot on lol
Old Apr 9, 2015 | 05:17 PM
costina's Avatar
costina
Update.
Do not buy HEL lines as a direct replacement YOU will need to make new hard lines to suit the shitty ends which are fitted to theses hoses.
Theses hoses have a concave and convex ends BUT will not seal correctly with standard ford hardlines.
Fucking pissed right off.
Pic above shows hel line with there save money end and a goodridge on the right.
Old Apr 9, 2015 | 06:05 PM
dojj's Avatar
dojj
Resident Wrestling Legend
ford, in their wisdom, decided to make some fittings in the chassis specific for the hose pipes and some not
always worth taking the time to look at the ends to see which need longer/shorter threads and which have the captive stuff on the ends built in
as for the op, it might have been that he's put the wrong hose on as it you get the full kit it's got 6, 2 for the fronts and then 2 per side for the rears
Old Apr 12, 2015 | 04:51 PM
costina's Avatar
costina
So HEL lines are fitted but what a pain in the arse. Had to remake 6 hard lines with a single flare to ensure good sealing. As the standard hardlines have a double flare which is not big enough to seal.
Sorry Mike for hi jacking your thread but are fellow cossie owners need to know the truth.
Thanks
Paul
Old Apr 12, 2015 | 05:26 PM
Cossy Mike's Avatar
Cossy Mike
Thanks
Paul
No bother, that's what it's all about (thumbup)
Glad you got it sorted
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
RsS2daz
Aug 14, 2015 05:26 AM
RSMK4TURBO
Aug 13, 2015 08:06 AM
track.focus'd
Aug 12, 2015 05:53 PM
