Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
parts cleaner
Old Jul 11, 2012 | 09:37 PM
james kiely's Avatar
james kiely
Default parts cleaner
im looking at getting a twenty gallon parts cleaner ,and have seen a few for 100/150 quid .
any advice on good or bad makes and the best degreaser to use would be appreciated
Old Jul 12, 2012 | 07:15 PM
james kiely
bump
Old Jul 12, 2012 | 07:21 PM
blue oval 24v's Avatar
blue oval 24v
you try some g101?good for engine bay's
Old Jul 13, 2012 | 12:42 PM
Mike C's Avatar
Mike C
The Special One
The Clarke stuff at Machine Mart is fine.
A lot of people also seem to use Jizer even though it's not listed as suitable for parts washers.
Old Jul 13, 2012 | 01:04 PM
james kiely
cheers guys ,i will look into those options
Old Jul 18, 2012 | 06:35 PM
nuttynil's Avatar
nuttynil
RS nutta
I've got an old safety Kleen washer you can find them on eBay as with fluid parafinn mix jizer
Old Sep 27, 2012 | 01:15 AM
AstoN_B's Avatar
AstoN_B
An eye for detail...
I found the machine mart stuff to be shite, better using cheap washing up liquid from supermarket!
Currently got a drum of jizer in there so see how that goes, seems better so far. There's also comma stuff and gunk.
Get down to motor factors and ask em about the drums of degreaser/cleaning fluid.
Old Sep 27, 2012 | 01:21 AM
AstoN_B's Avatar
AstoN_B
I got a cheap copy of the Clarke big floor standing washer, purely cause its a good base, simple too. If the pump eventually goes ill buy a Clarke proper one, only a 15 minute job to swap. Seems fine at moment though.
In essence it's just a metal tank with a pump in it, I wouldn't want to pay over the odds for someone putting a fancy sticker on the front.
Check makro etc, think mine was from JTF. less than £100. Came with shelf and deep tray for smaller parts too, proper o ringed drain plug and self closing fire hinge too.
Though I had to drill a couple holes different for the lid opener cause it only opened abut 45 degrees, now goes about 85 and closes about half inch short. Which is fine cause I put stuff on it when not in use anyway.
gambo08
Feb 4, 2016 10:49 PM
Oct 1, 2015 02:00 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fordmad!
Sep 29, 2015 07:03 PM
