4x4 Cossie T3 onto CVH... quick help please!!
Ive got my Cossie T3 bolted onto an Escort RS Turbo manifold which is attached to my FRST block. I obviously need to use a cossie downpipe due to the 3 studs on the end of the turbo (not a problem), but what happens with regards to the oil return/feed pipes?
Does anyone know if a standard Escort RST one will fit straight onto the turbo? And wherabouts does the oil return pipe goto on the FRST block/turbo?
Chris
Chris
u need to use std rst piprs bolted onto the cossie turbo. The oil return outlet on the cos turbo is in a different place, so u need make up a longer hose to connect to the block.
ok cool cheers! Where abouts is it on the cossie one as i couldn't see it (all beit a little dark).
To confirm (before i buy one!), the RST oil return pipe from near the oil filter to the turbo is the one to use?, and I need to make up a longer rubber pipe for the other oil pipe?
Chris
Chris
truffleshuffle
Sep 10, 2015 09:35 PM
Thanasis
Sep 7, 2015 07:33 PM
Adam Graham
Sep 6, 2015 06:04 AM
