Engine braces.
Old Mar 3, 2005 | 03:51 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default Engine braces.
Nobody ever thought of fitting one to a Cossie? Seen it done on various other cars, a solid bar from the engine to the body to stop the engine twisting (well trying to rotate) on its mounts.
Helps torque transfer If engine cant try n turn itself i guess it puts more into the transmission.
Should work like solid engine mounts with regard to handling too.
Seen it done with a small shock absorber type thing but all that does it keep engine still rather than what a solid one would do, as theres less movement rather than none.
Anyone know much about it? As i dont
Old Mar 3, 2005 | 03:59 PM
GARETH T's Avatar
GARETH T
if you fit real group a ( ) solid engine mounts the engine isnt going anywhere if you think about how the engine i held too the subframe
Old Mar 3, 2005 | 04:05 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
True. Not many people do tho, most peoples engines are flopping about all over the shop when on the power!
Old Mar 3, 2005 | 04:07 PM
GARETH T's Avatar
GARETH T
Itsmeagain, tbh the engines dont move much at all,,, im sure wheelspin is prevoked before the engine moves though massive angles
Old Mar 3, 2005 | 04:08 PM
Spiky's Avatar
Spiky
Old Mar 3, 2005 | 04:21 PM
RichardPON's Avatar
RichardPON
Solid mounts like Spiky's or Group A mounts like mine:
Can't see the point of bracing the engine to the body - shock and vibration if EVERYTHING was solid mounted would be huge!
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
mint_s2
Sep 2, 2015 08:58 AM
