MT75 center push clutch set up
Old Jul 2, 2012 | 03:00 PM
M K's Avatar
M K
Default MT75 center push clutch set up
I am going to be running hydraulic clutch on the fiesta, i have the pedal side as i am running a tllton pedal box so thats no problem but i do not really want to run the original clutch arm set up with a cylinder bolted to the box casing
Has anyone done a center push set up for the MT75? i am running an ap twin plate 7.25" clutch set up if that makes a difference
If no kit is available then what things do i need to know to determine the travel etc and cylinder sizes required?
Someone must have done it before so thought id ask here
Any info appreciated
Thanks
Marc
Old Jul 22, 2012 | 12:45 AM
markk's Avatar
markk
I made one years ago by turning the nose of the std input off and weldong some flats to tap and fit a tilton release bearing setup, but there are factory hydraulic mt75's 2.5 diesel scorpio iirc - seam to be bloody expensive though at times
yatta
May 21, 2016 10:31 PM
Rsmat
63
Sep 25, 2015 12:11 PM
Adam Graham
Sep 6, 2015 06:04 AM
turbowag
Sep 3, 2015 08:07 AM
Cragrat
Sep 2, 2015 08:25 PM
