Ford Range This section is for other models in the Ford range.
Springs and shocks on my mk3?
Old Jul 1, 2012 | 12:44 PM
cori_southwales's Avatar
cori_southwales
Default Springs and shocks on my mk3?
hi,
Can anybody tell me if i put a 1.6 Engine and box into my 1.3 mk3 escort
will i have to put bigger shocks and springs in to take the weight?
Thanks
Cori
Old Oct 28, 2012 | 06:40 PM
B3rtie's Avatar
B3rtie
Originally Posted by cori_southwales
hi,
Thanks
Cori
If it is a 1.3 CVH to 1.6 CVH - No as the weights are similar. All the part numbers are the same for both models except the pre/post 1983 differences to the front shocks (which wont impact on your engine swap). You might want to consider whether you want to use a 1.6 'box though as final drive is higher geared in comparison to the one in the 1.3 'box.
Rod-Tarry
75
Oct 13, 2015 04:44 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Steve Escos
Oct 1, 2015 06:57 AM
SMILER258
Sep 28, 2015 09:04 AM
