Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
New member, brake advice please!?
Old Jun 29, 2012 | 05:18 PM
James B's Avatar
James B
Default New member, brake advice please!?
Hi, I've got a mk2 1600 Focus and just recently had it MOT'd and it passed fine. Although I've noticed a squeeky/metalic rubbing noise is progressively getting worse.
It doesn't sound like a bearing as I've had that problem on previous cars and work vans.
It seems to be at a slow pull off or if crawling in traffic etc, but isnt a constant noise. Sometimes can hear it at higher speeds but usually once been driving for a few miles and getting upto temperature.
I tried removing the front wheels and grinding off the edges of the discs and banging off the crust around the edges of the discs and that seems to help for about 2 days and then it just started coming back.
Im thinking its best to just renew discs and pads now and see if it stops? If so which is a decent brand for a daily drive.
Sorry for a long post just wanted to be clear.
Thanks, James.
Old Jun 29, 2012 | 07:13 PM
the_frozen_one's Avatar
the_frozen_one
Whatever Brakes International send ya, cheap, good service and often made by the same firm that makes ford branded parts
Old Jun 30, 2012 | 06:05 PM
James B's Avatar
James B
I looked on that site after you recommended it and couldnt find how to order anything?
rex647
Mar 6, 2022 06:20 AM
yatta
May 21, 2016 10:31 PM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
