Oil In Header Tank
Old Jun 29, 2012 | 10:08 AM
Mids_s2's Avatar
Mids_s2
Default Oil In Header Tank
Hi i was wondering if anyone could shed any light on my coolant having a layer of oil on top which has stained my header tank?also another question iv had my gearbox rebuilt and replaced the release bearing but there is still a rattle when taking up drive (sounds like release Bearing) any ideas as im using an AP paddle clutch.
Cheers for any advice
Ben
Old Jun 29, 2012 | 10:18 AM
andremarca's Avatar
andremarca
There are not many reasons for the oil on the header tank... Busted oil/water permutator, cracked block, cracked head, cracked turbo.
I had a problem when going for bigger pistons. When the cylinders where bore, because of some corrosion, there were some really small holes not visible to the naked eye that leaked water to the sump when hot.
Maybe someone can shed a light on this...
Old Jun 29, 2012 | 11:45 AM
Mids_s2's Avatar
Mids_s2
thank you for your fast reply,i can rule out the turbo leaking as its an air cooled one,im hoping it isnt the cylinders bein cracked as its will be an expensive job,is it possible for the head to lift under higher boost pressures??i was hoping it would be head gasket so its easier to fix.
Cheers Ben
Old Jun 29, 2012 | 01:24 PM
Karlos G's Avatar
Karlos G
Balls Deep!
IMO Most common cause will be HG mate.
Old Jun 29, 2012 | 03:30 PM
series_one_rst's Avatar
series_one_rst
head gasket or oil cooler?
Old Jun 29, 2012 | 04:20 PM
STeve's Avatar
Super Moderator
HG gets my vote
Old Jun 29, 2012 | 08:03 PM
minder's Avatar
minder
def head gasket
Old Jun 29, 2012 | 11:12 PM
Mids_s2's Avatar
Mids_s2
Thanks for your replies guys I'm hopin it's HG, another quick question what you think the noise could be as I'm takin up drive does anyone else suffer with a rattle with a paddle clutch?
Cheers Ben
Old Jun 30, 2012 | 09:04 AM
dazrsturbo's Avatar
dazrsturbo
hope you get the oil issue resolved! i also have a rattle/knock noise when accelerating so would be good to see what ppl suggest
Old Jun 30, 2012 | 12:53 PM
johnnysash's Avatar
johnnysash
Could it be engine mounts or more specifically gearbox mounts knackered?
Old Jul 1, 2012 | 08:42 AM
Mids_s2's Avatar
Mids_s2
Hi,I'm running vibratechnics gearbox mounts and just a standard engine mount it sounds more like internally to the gearbox but I want to change mount so I'll try that to illiminate that.
Cheers for your help
Old Jul 1, 2012 | 08:50 AM
the_frozen_one's Avatar
the_frozen_one
I'd say oil cooler
Old Jul 2, 2012 | 10:03 AM
Mids_s2's Avatar
Mids_s2
Cheers,where is the oil cooler?? is it where the oil filter sits on??are the seals easy to change??
Cheers Ben
Old Jul 13, 2012 | 07:40 AM
Mats1985's Avatar
Mats1985
I have this problem oil in header tank can't b headgasket changed that in the last couple of days cus had pressure in water system all the time would a dodgy oil cooler cause pressure aswell
Old Jul 13, 2012 | 08:10 AM
the_frozen_one
Yes, oil pressure is much higher than water pressure, that's why when the cooler fails oil goes into the water rather than water into the oil.
Old Jul 13, 2012 | 08:17 AM
Mats1985's Avatar
Mats1985
Sound iv changed everything trying to find out why there's pressure in header tank but was only doin it when It was turned off but there wasn't any visible oil in water b4 so changed headgasket and had head skimmed and tested was all fine built it back up still pressure now oil in water
mpilk
Sep 27, 2015 09:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dickdastardley
Sep 24, 2015 08:43 PM
