Ford KA Discuss your Ford KA here!
Ka chassis repair opinions
Old Jun 28, 2012 | 05:46 PM
fordy1's Avatar
fordy1
Default Ka chassis repair opinions
Hi all. I have recently bought an old Ka which has had a repair done to the rear chassis leg above the exhaust where it had corroded through and the end of the chassis leg had been ripped off the car by the weight of the exhaust. This is the repair that the previous owner has done and I just wondered whether it is ok or whether I should do something about it before its next MOT. It is absolutly solid, I had all my weight on it and it didn't budge so I'm thinking it is OK? Opinions welcome!
Old Jun 28, 2012 | 06:21 PM
Adder's Avatar
Adder
It dose'nt look pretty but it will be fine for the mot !
Hope this helps
Adder
Old Jun 28, 2012 | 06:28 PM
James's Avatar
James
I would say it's not a continious weld so a fail i'm afraid.
Old Jun 28, 2012 | 09:07 PM
fordy1's Avatar
fordy1
Thats a bit of a pain. Especially as I am pretty sure this is now the strongest part of the car!
Old Jun 29, 2012 | 09:43 AM
swain78's Avatar
swain78
I agree with james as it not a continuous weld its a mot failure. Underseal plastered n really really thick hides a multitude of sins
Old Jun 30, 2012 | 12:40 PM
Adder's Avatar
Adder
The thing is, the area that has been repaired is not a prescribed area ! Therefore, this would pass a mot test.
Adder
Old Jul 2, 2012 | 09:04 PM
studabear's Avatar
studabear
Adder
Correct that is more than 30cm from any prescribed areas so in reality it would pass with body filler and newspaper
Old Jul 3, 2012 | 04:57 PM
Hobomassiv's Avatar
Hobomassiv
you could ask a friendly MOT man to check it and give an opinion, and then get it modified if needed, would only need a welder i guess
Old Jul 21, 2012 | 06:01 AM
Matt Baxter's Avatar
Matt Baxter
Back in black!
just to confirm that ^^^^ is spot on (I'm a tester ) put the exhaust back up there and i doubt it would get a 2nd look tbh
Old Jul 21, 2012 | 06:08 AM
vaughant's Avatar
vaughant
Id put a little run of seam sealer along where it's been plug welded just to prevent moisture ingress then put a bit of underseal back over it.
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
rsguy
44
Sep 29, 2015 03:29 PM
