T34 Turbo actuator rod / turnbuckle length
Old Jun 26, 2012 | 07:43 AM
Dennis_Wiseman's Avatar
Dennis_Wiseman
Default T34 Turbo actuator rod / turnbuckle length
What length in mm's is a T34 actuator rod / turnbuckle ?
Old Jun 26, 2012 | 10:37 PM
Dennis_Wiseman
Anyone? Surely not a hard question
Old Jun 27, 2012 | 02:24 PM
coswurv's Avatar
coswurv
Do you mean the part that screws on the threaded actuator rod, the part with the hole in the end that drops over your wastegate pin ?
Old Jun 27, 2012 | 06:06 PM
Dennis_Wiseman
Exactly that mate yeah
After searching about there appears to be 3 different lengths for the Cosworths.
Old Jun 27, 2012 | 08:38 PM
coswurv's Avatar
coswurv
If that's what you want mine is about 78-79mm
Old Jun 28, 2012 | 07:51 AM
Dennis_Wiseman
thanks mate much appreciated
Old Jul 9, 2012 | 06:02 AM
Stu @ M Developments's Avatar
PassionFords Creator
Depends if you have an original spec actuator if you have fitted one from a Sierra like the guy above.
Old Jul 25, 2012 | 12:10 PM
Dennis_Wiseman
Its a Escort Cosworth 31 actuator bought from your place Stu so basically my full set up turbo side is stock escort cos. I emailed a couple of months back but you don't keep the rods i was told.
Contacted a few other places since and most replies were measure it or total head scratching as to what length it should be.
Seems to be a lot of people running a non matching turbo to actuator. Not sure if it makes a difference in the running or not?
Old Jul 26, 2012 | 07:40 AM
Not in the slightest mate. If you still have the adapted turnbuckle to fit a Sierra length -31 to the car then if you want to pay the postage, fire it back to me with a note and I will swop it for a Sierra version mate.
Old Jul 26, 2012 | 10:13 AM
Dennis_Wiseman
Thanks Stu but i would be no better off switching to Sierra as i would still need to find a actuator rod for that lol
Is 140mm about the length of the Escort Cos actuator rod?
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
