Wheels and Tyres Wheels and Tyres for all Ford's
RL7 Offsets
Old Jun 25, 2012 | 07:31 PM
cossiestu's Avatar
cossiestu
Default RL7 Offsets
Just wondering if anyone knows where the 'ET' stamp will be on a Raceline RL7...
Got a spare set, but can't remember what offset they are. Can't get to them to check at the moment, but thought I'd ask first....
Thanks
Old Jun 25, 2012 | 07:41 PM
ginner's Avatar
ginner
R u selling them mate are they 18s
Old Jun 25, 2012 | 08:08 PM
cossiestu's Avatar
cossiestu
Sorry, they're 7 x 17's
Was maybe thinking of selling them, not sure what they're worth. I need to have a think...
Old Jun 25, 2012 | 09:07 PM
rog's Avatar
rog
On the front of the wheel, near the outer edge between the spokes, I don't know how else to describe it, but it should be easy to find.
Old Jun 25, 2012 | 09:27 PM
andym's Avatar
andym
Some ain't marked, my 18" RL7's don't have any markings at all.
Old Jun 25, 2012 | 10:17 PM
cossiestu's Avatar
cossiestu
Rog, thanks, I was thinking that, as I don't remember seeing anything on the back of the spoke..
Andy, I was afraid someone would say that! Thanks, hopefully ill find something, if not, have to measure it...
Old Jun 26, 2012 | 04:39 PM
gus's Avatar
gus
i have half a dozen sets and none of em are marked
sorry
out with the tape and straight edge
Old Jun 26, 2012 | 05:43 PM
cossiestu's Avatar
cossiestu
Arse! Couldn't be easy!? Think I've got the receipt for them somewhere....
If not, ill measure it and do the maths!
Cheers guys!
Old Jun 30, 2012 | 04:10 AM
COCHYN's Avatar
COCHYN
As above, measure them, easy enough.
@ Gus
Do you have any 18's not in use, need 1 spare
Old Jun 30, 2012 | 06:24 AM
gus's Avatar
gus
nope no 18's
wouldnt ,mind set for my fez
Old Jun 30, 2012 | 07:57 AM
cossiestu's Avatar
cossiestu
Am I right in thinking its the distance from mounting face to the outer rim?
Old Jun 30, 2012 | 10:36 AM
gus's Avatar
gus
First, measure the overall width of the wheel (remember, just because a wheel is 18x7.5, does not mean that the OVERALL width is 7.5”. It means that the measurement between the outboard flange and the inboard flange is 7.5”). Next, divide that width of the wheel by two; this will give you the centerline of the wheel.
Overall width/2 = Centerline
After determining the centerline, measure from the hub-mounting surface of the hub to the edge of the inboard flange (if the wheel were laying flat on the ground – face up – your measurement would be from the ground to the hub-mounting surface). This is your back spacing.
Back spacing - Centerline = Offset
Old Jun 30, 2012 | 11:58 AM
JayCC's Avatar
JayCC
Great post. Very helpful, thanks!
Old Jul 7, 2012 | 12:24 PM
cossiedad's Avatar
cossiedad
My RL7's have no offset marked either. Am interested if anyone has a set of 7 x 17's for sale? Will be fitted to 2wd saff so offset somewhere around 35 - 45 I think?
cheeRS
Old Jul 7, 2012 | 01:48 PM
gus's Avatar
gus
cheeRS
you and me both
COCHYN's Avatar
COCHYN
Just measure them, very easy to work out
Old Jul 7, 2012 | 03:00 PM
cossiestu's Avatar
cossiestu
Thanks for that! Mine are 7x17, might be think about selling them, as they don't fit over my AP's....
(Which may make them not worth much!?)
Old Jul 7, 2012 | 05:28 PM
gus's Avatar
gus
what size brakes have you then?
thought you could get big ap's behind 17's
Old Jul 7, 2012 | 06:44 PM
cossiestu's Avatar
cossiestu
Not sure of the AP part number, but they're 4 pot TVR Calipers, (same as a Clio V6) with 330 mm discs. Offset wasn't quite big enough to clear. Might do with some spacers I guess? Once I can get the car out the garage, ill get them out and decide what to do with them...
IainRS1700T
Sep 25, 2015 06:44 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
turbotrev
14
Sep 6, 2015 10:27 AM
track.focus'd
Aug 12, 2015 05:53 PM
Andy.B
Ford Focus RS
Apr 4, 2004 08:10 PM
