life expectancy of big bhp cvh zvh cossie
Old Mar 3, 2005 | 12:03 AM
ProjectBobcat's Avatar
ProjectBobcat
out of interest what nationality are you?
Old Mar 3, 2005 | 12:06 AM
mattbibs's Avatar
mattbibs
karls has supposed to have lasted 20000+ miles hasnt it?
cant say fairer than that for any performance motor and his isnt just slightly tweaked is it?!
Old Mar 3, 2005 | 08:06 AM
Karl's Avatar
Karl
Norris Motorsport
Generally speaking, I advise any engine running 200+bhp/litre to be freshened up at 10,000miles, but this is of course dependant on usage, and just how fussy you are with regard to engine condition.
Old Mar 3, 2005 | 08:51 AM
Paul Eggleton's Avatar
Paul Eggleton
Karl, what do you class as a freshen up?
New rings, shells, hg etc? anything else in the head for example?
Paul.
Old Mar 3, 2005 | 08:59 AM
Karl's Avatar
Karl
Norris Motorsport
Paul, its totally down to wear rates as to what needs replacing and this is down to type of usage. When I quote 10K miles thats assuming the car is for weekend use and trackdays only, so that most of the 10K is relatively hard miles.
At a freshen up the main areas to check for wear are bores/rings, shells, oil pump, cams/followers and valve guides. All other parts tend to be reused except for the new gaskets of course.
If the bore wear is good, then it will consist mainly of a rehone and new rings, new shells, check oil pump, new valve guides and seats recut and then rebuilt.
Hence you can see the big cost at a freshen up comes from whether the bore has worn. In this case its a rebore and new pistons which adds significant cost. Most however are ok at 10K and usually require a bore at the next 10K freshen. (i.e. 20K miles total)
Old Mar 3, 2005 | 11:42 AM
hI
My old 500bhp conversion did 23k before it needed a re-build.
It still ran well & recorded 0-100 8.1 & 181.8mph on its last event, however I knew by this stage it was past its best , one week later it was inspected & found to have a worn Turbo & a badly worn inlet cam.
Rod
Old Mar 3, 2005 | 12:17 PM
Rick's Avatar
Rick
Old Mar 3, 2005 | 12:23 PM
Paul Eggleton
Nice one Karl. You have email as well
bigryrs
Mar 28, 2016 09:11 PM
Del gsxr
Feb 11, 2016 05:37 AM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
Blown Hell
Aug 5, 2015 07:22 AM
knight19770
Aug 4, 2015 12:36 PM
