Cambelt change (belt movement) & Tensioner Weeping
Old Jun 24, 2012 | 06:30 PM
Nick H's Avatar
Nick H
Default Cambelt change (belt movement) & Tensioner Weeping
Hello,
I wonder if anyone can help, I have just changed the cambelt and tension on my escort cab rs turbo.
The belt seems to move quite a bit at the front at different revs, it is the same as the old one but I thought that one might be a bit stretched, the tension is good at the back and you can only get about ¼ turn at the front (belt check)
The other issue is that the new tensioner has thrown out quite a lot of green grease when hot, could the seal be bad?
Thanks.
Old Jun 24, 2012 | 07:34 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
Belt sounds normal to me but I'd say the tensioner should be sealed so shouldn't leak any grease imo
Old Jun 25, 2012 | 10:14 AM
Karlos G's Avatar
Karlos G
Balls Deep!
It's funny this should crop up, I fitted a new tensioner to my ZT a couple of days ago and noticed after a run that blue/green grease was all over it... Cleaned it off and hasnt returned since?!
Never had this happen before though.
dombanks
Sep 21, 2015 08:38 PM
marky_g
Sep 12, 2015 04:26 PM
Adam Graham
Sep 6, 2015 06:04 AM
rsturbo27
Sep 5, 2015 05:08 PM
