Efi cabriolet to efi turbo?
Old Jun 22, 2012 | 10:56 AM
bigryrs's Avatar
bigryrs
RSHoleinator
Default Efi cabriolet to efi turbo?
Hey folks I know the engine slots straight in no probs as I've removed and replaced a few but never mucked about with efi stuff before! Because my cab is already efi can I plug the frst engine loom and ecu in and run it as is or do I need to splice some wires together? Cheers in advance for replys etc
Old Jun 22, 2012 | 03:18 PM
mentalasanything's Avatar
mentalasanything
Have a read of the sticky at the top of the room. You can literally slot the engine in and connect it to the existing loom. Then add an OFAC ECU and MAP sensor and you have a cheap upgrade. No new looms required.
Lee
Old Jun 22, 2012 | 05:21 PM
wedge07's Avatar
wedge07
I think with ofab u need change two wires at ecu ones an 02 n cant remember wat other was.
Wen i put my ofab in i wired it via two yellow relays.
Ran mint for a year daily until i recently stripped it for a reshell.
This time im after a 1.3 shell with no sunroof and will use my full xr3i efi loom and wire it propperly. So my new ofam ecu sits between footwells. Its a doddle if ur already on efi mate
Old Jun 22, 2012 | 07:44 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Aw tidy that will be my winter mission! Hunt for a frst engine starts once im back from holiday!! Cheers lads
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
RSBryden
Sep 6, 2015 08:39 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
