Losing interest...
Ive been enjoying working on my Orion less and less lately, i still enjoy driving it but the oppurtunites when i get to are few and far between at the moment as ive just brought a house and am busy "modifying" that lol...
Im really considering selling or breaking it
as it needs so much work to get it to the stage im happy with, bodywork, clutch and a few other bits...
What have you guys done to get some interest going in your cars again and what do you recommend?
I just started coulour coding my engine bay,when I got it the rocker cover was the typical coulour but looked ruff,I have painted that red,2k and laquer,have sprayed the crossover pipe alluminium,have put a red top boost hose onit,red coupler to throttle body,bit of red vacuum pipe,braid fuel filter pipes,sorted th speakers and 2 new front grills off twins,put a new rubber rocker gasket on with torque washers,gave it a mini service,tip dont use a cheap oil filter remover,mine ended up spraying oil all over the engine bay so cleaned most of that up,new decent sony cd player,new drivers recaro seat,now it needs a plate on the back but would rather a solid one thats had abit of welding then a shock one thats rotten to fuck,starting to get there with mine slowly,its also had a new zetec starter and the wiring behind the dash sorted
If you do break it sell me your floflex gearbox mounts!!
lol
But seriously, we all lose interest at times so maybe a break from it is whats needed then come back a fresh and get stuck in!
lolBut seriously, we all lose interest at times so maybe a break from it is whats needed then come back a fresh and get stuck in!
Don't be such a tart
But I know exactly how you feel. Just leave it alone for a while. I've parked my car up for a year now. Getting on with the flat etc and other projects but now I'm itching to get back on with it. Really really want to just head down to the garage and have a play. I think you will be the same.
Plus the edis replacement unit is just about done, just need a willing guinea pig to test out some launch control...... know any one with an RS Onion and OFAM?
Rob,
Rob,
Last edited by Rob_DOHC; Jun 21, 2012 at 06:18 PM. Reason: Forgot to take the piss
I lost interest over the winter just gone and decided to break it but i kept looking at it and decided against it..So then i decided to give it to NMS to build me a car and i cant wait to have it back!
Not really an incentive but the point is i lost interest for 6months then gained it!
Thanks, Joe
Thanks, Joe
In theory, yes. But I haven't tested it at all yet. So in reality no... but its coming
Launch control/flat shifts cooler though and probably more useful on the road.
Rob,
Rob,
Rob -
Turbo'd Orion - Check...
OFAM - Check...
Just need to find the enthusiasum lol...
No seriously m8, you know you just have to let me know when your coming down and i'll be waiting!
OFAM - Check...
Cheers buddy, I'll keep you in mind. You need an extra module for it to work too, we generally test our proto stuff on Roger but if he's not about I'll give you a call
I;ll probably test the anti lag on my car first (need to drag it out the garage any how) as in theory mine is all ready setup for it.
Cheers dude, we need a good catch up soon any how
Rob -
OFAM - Check...
OFAM - Check...
Matt - OFAM "road wars" is where its at... I'd like to get mine on some rollers at some point tho! If you need a hand with anything OFAM related m8 let me know, if not Rob-DOHC is very helpful!
Rob - How soon is it gonna be ready for testing...
Launch control and flat shits sound nice idea need to map mine still yet tho just got it ideling good
Roger dont get rid if you have to just put it away for a bit and you will soon get your enthusiasm back sounds like you have a bit just on this thread
Im not really too sure yet. I have the proto-proto type on the bench at the moment, but this is really only for bench testing and couldn't easily be plugged into the car. Im testing out a new type of ignition driver I came up with so want to make sure its nice and reliable first, but so far after an hour of full on spark fun the drivers were still nice and cool.
I'll give you a bell at somepoint mate, but i'm booking the dyno for a day soon so will pass on the dates etc.
Rob,
Sorry to steal your topic Rog, but while I've got all the OFAM/Megasquirt boys in one thread, what wideband do people recommend for use with MegaSq?
I'm currently looking at:
http://www.ebay.co.uk/itm/270997328827
ZX - Good advice!
Matt - that one is what i run, excellent although takes 20-30secs to "heat" to operating temp so you can't map the 1st 20-30secs of idle...
We should all get together Rob, plenty to chat about!
Right thanks gents, I'll be getting an MTX then, you can now return to convincing Roger to crack on with his car
Indeed Karlos, would be good to meet up some time!
From memory, although the wb heats up with ignition on, it doesn't heat up fully. So readings are still a bit iffy. Rogers doesn't give useful readings until the engines been on for 20-30 seconds.
That WB looks good, you can pretty much use any setup so long as it has a 0-5V output. AEM, innovate, techedge etc. All should work well.
Rob,
Rob,
Rob,
Rob,
My Techedge heats up fully and reads fine after about 1 min with the ignition on, perhaps the heater in the Innovate isnt quite as agressive?
Not much use if it doesnt as cold start mapping will be a right pain! lol
Im always losing interest but cant give up as ive got too much money in the car to sell it as id lose a fortune . I sometimes find it hard to motivate myself to do anything when i go to the workshop due to being knackered everytime i go in there , but then i have to slap myself and just get on as it wont do itself pmsl
steerfromdarear
28
Jan 29, 2016 06:14 PM
liamT74
Sep 23, 2015 10:24 PM
