Cortina rev counter
Hi guys can anyone advise me I have changed my car to electronic ignition original had a ballast resistor. So I put a new live from ign switch to new coil (non ballast) and new distributor fitted with Accuspark electronic ignition. Car timed up well and runs well however the original leads going to coil one white the other white and pink both went to same terminal on coil however I need to know what one to connect to make rev counter work, as it has it does not move since. Any help would be great as do not want to connect the lead with ballast in line. Cheers.
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
