Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Mk 2 Cortina rev counter Help
Old Jun 15, 2012 | 08:33 PM
Peter Westaway's Avatar
Peter Westaway
Default Mk 2 Cortina rev counter Help
Hi guys I,ve just changed to electronic ignition (Accuspark) runs well but due to original being a ballast resistor type put standard coil on and seperate live to coil from ign switch. However Rev cunter not working does anyone know what wir I connect to coil A choice from two white or white with pink. As a ballast is fitted in line I do not want to connect wrong one. any help has haynes book is no good. Cheers
Old Jun 16, 2012 | 05:57 PM
minder's Avatar
minder
hi mate its the white wire you need to connect to the coil done it many times in the past
and never had a problem
Old Jun 16, 2012 | 06:35 PM
Peter Westaway
Cheers Minder done it works good but bounces about now and again. But did that before any way may need another?
Old Jun 20, 2012 | 06:56 PM
minder's Avatar
minder
no worries mate glad you got it sorted
TPM961
Jan 15, 2018 10:50 AM
20/20 vision
Sep 29, 2015 11:27 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
