St170 Timing belt snapped and blew the inlet manifold off!
Hi..
Tonight the cambelt snapped on the St170 and due to the pressure blew the inlet manifold out of its 4x retaining hose clamps! It went at low revs.
Does anyone know if these engines are prone to bent valves etc or should I chance fitting a new belt and compression checking it first? Wisful thinking maybe??
Your help and advice would be much appreciated.
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
99% probability it will have bent the valves. I've had a couple of belts go on my cars in the past and even just jumping 2 teeth it bent all the inlet valves...
thanks guys. on inspection tonight it has no compression by turning the bottom pulley with a spanner very carefully- so head off tomorrow. Hope the damage is confined to the head only and not the whole lot fingers crossed!
Any info or links as to re-timing it all back up again and VVT explanation would be much appreciated? ... not sure how its done on one of these
Got the battery off etc so not sure of exact mileage, 80k roughly. Due a cambelt on time rather than mileage according to service history. It was the tensioner that caused it.
Again, any cam timing info much appreciated .... this week it will be re-assembled with a new head.
Ive just bought one on 102,000 miles on the original belt. it was proper fluffy and stringy under the cover ! Caught it in time ! Just turn the crank till the marks line up put a blob of nail varnish on each pulley when they are inline is how i did it, didnt need anything different timing up to a normal zetec
Yeah must say done loads of belts on these if the pin and bar go in leave the VVC alone same as with the Clio Cups etc
Anutternutter
Aug 21, 2015 06:07 PM
track.focus'd
Aug 12, 2015 05:53 PM
