How runs coilovers on there s2?
Old Mar 2, 2005 | 02:40 PM
Tim's Avatar
Tim
Default How runs coilovers on there s2?
Dont mean the avo half kit full kit front n back whats the verdict on makes Gaz etc?
Tim
What lbs springs you run?
Old Mar 2, 2005 | 03:04 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
i'll have a set of GAZ coilovers very shortly
to run this set up
https://passionford.com/forum/viewtopic.php?t=95490
not sure what lbs springs i'll have yet tho
Old Mar 2, 2005 | 03:15 PM
CliffRS4's Avatar
CliffRS4
I run Bilstein Coilovers on the back ( Same as NutsRus car )
and Avo coilovers on the front.
The Bilsteins were a very reasonable price.
I can pass the blokes phone number on if you want, just pm me if you are interested
Old Mar 2, 2005 | 04:07 PM
lamar69er's Avatar
lamar69er
Ive just some GAZ coilovers for mine, not fitted them yet cuz of the bloody weather, no point fitting them either as the roads are still slippy... Should get them on in the next few weeks, and hopefully will warm up a bit!
The workmanship looks superb on the GAZ units, and look better made than the Avo's. But I'l wait to see how good they really are... cant wait to ditch the koni's thou
Old Mar 2, 2005 | 04:08 PM
Charlie Chalk
Unknown.
nor me
Old Mar 2, 2005 | 04:50 PM
Tim's Avatar
Tim
All ready ordered some anyways ,cheers Dave at Dampertech in rotherham great bloke
My rear arches are already welded up and reinforced etc what have you done?
Old Mar 2, 2005 | 05:23 PM
nigel b's Avatar
nigel b
nor me
coz you aint got them yet
ive run gaz coilovers all round
work quite well on the track too
i think the springs are 200/250lbs
now im using bilstein front and rear courtesy of mef
Old Mar 2, 2005 | 06:19 PM
lamar69er's Avatar
lamar69er
Tim what welding mods have you done to your car???
I was going to try using the rear coilovers with just a Fusion rear strutbrace to start off with! I have been toying with the idea of using some of MEF Motorsports rear arm setup... as well
not sure yet!
Old Mar 2, 2005 | 07:20 PM
Tim's Avatar
Tim
The seams really need to be welded up unless you have a proper cage and weld in rear strut brace etc.
Old Mar 2, 2005 | 07:21 PM
Tim's Avatar
Tim
nor me
but can u tell a diff in the two ?
Old Mar 2, 2005 | 08:19 PM
Andy-R's Avatar
Andy-R
Tim Im running Leda coilovers, the rear has been strengthened & had new strut housings fabricated. Spring rates are 250lb fronts & 120lb rears.
Old Mar 2, 2005 | 08:55 PM
escort1989uk's Avatar
escort1989uk
would you benift from coilovers on the front and koni adjustables on the rear
Old Mar 2, 2005 | 09:04 PM
Liero's Avatar
Liero
What's the price on the Bilstein coilovers?
Old Mar 2, 2005 | 09:19 PM
nigel b's Avatar
nigel b
nor me
havent been on track since the new gear was fitted and the car needs setting up again after more changes to engine and suspension
Old Mar 2, 2005 | 09:57 PM
Ollie's Avatar
Ollie
Looks good Tim lad
think my rears are 100- 120 ish cant remember can find out like 4 u , its a bit down 2 damper ratings and how u like the car to feel though , personal prefference, there is no set thing , trial n error lol
Old Mar 2, 2005 | 10:02 PM
Rick's Avatar
Rick
the springs are quite cheap i think, so u can play around. Want mine quite soft for the road.
Old Mar 2, 2005 | 10:39 PM
Tim's Avatar
Tim
Aye up ollie lad ,things commin on slow lol pissin around with the claw-tel defi's but its too cold at moment lol,will be over soon for a chat.
jessie_rs
62
Aug 6, 2019 09:27 PM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
yorkie92
Sep 6, 2015 05:34 PM
Adam Graham
Sep 6, 2015 06:04 AM
