Seam welding
Old Jun 10, 2012 | 08:39 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Default Seam welding
Can anyone shed some light on this? While I've got the Fiesta down to a bare shell, I've though about seam welding it. I know you weld an inch, leave an inch, and keep moving around the car so you don't get too much heat build up. My question is, do you just weld the seams that are covered by seam sealer?
Any help appreciated.
Ben.
Old Jun 10, 2012 | 09:04 AM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
should give you an idea
Old Jun 10, 2012 | 09:16 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Quite literally every seam then!
Is he TIG welding that? It generates more heat than MIGing doesn't it?
Old Jun 10, 2012 | 09:20 AM
Cossie Sean
first one is TIG, obviousley it is not esential
just make sure the metal is Uber clean, and dont just do a bit here and there or it will stress fractire where you havent
Old Jun 10, 2012 | 12:15 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
I always thought you had to do bits all over to prevent heat build up in one area?
And what's best to get rid of the paint, a wire wheel on a grinder?
Thanks
Ben.
Old Jun 10, 2012 | 12:18 PM
Beetlejuice's Avatar
Beetlejuice
TIG will give you the ability to put less heat into the shell.
Old Jun 10, 2012 | 12:21 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
The steel cools pretty quickly, just don't go mad. Your better off stitching it so it doesn't crack. Wire brush on the grinder is best for getting rid of seam sealer.
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
