Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
help locating lambda sensor please
Old Jun 9, 2012 | 06:03 PM
blader1611's Avatar
blader1611
Default help locating lambda sensor please
i am looking for sensor 1 bank 1 lambda sensor. i have found what i believe to be two sensors at the back of the engine but lord only knows if this is right so looking for clarification. If you peer over the engine towards the windscreen, it looks like the exhaust manifold comes out there, I can see two sensors (one left and one right) that look a little like spark plugs i guess. Am i right in thinking these are the lambda sensors and if so which one is sensor one bank one? one seems to go to a green plug and the other goes to blue.
Old Jun 11, 2012 | 05:10 PM
Greasenuts's Avatar
Greasenuts
Bank 1 relates to the bank of cylinders which includes number 1 cylinder, bearing in mind that a 'V' configuration engine has 2 banks of cylinders. So an in-line 4 cylinder engine only has "Bank 1".
Sensor 1 relates to the position of the sensor along the length of the exhaust. Sensor 1 being closed to the engine, always before the catalytic converter, while Sensor 2 (if fitted) is after the cat. Ive heard of Sensor 3, but yet to come across one...
So, your "Bank 1, Sensor 1" is the sensor closest to the motor.
Hope that helps.
Old Jun 11, 2012 | 06:33 PM
blader1611's Avatar
blader1611
Thanks greasenuts, problem is i have 2 close to the engine and I cant determine which one is sensor 1? they are side by side so one isnt closer to the engine than the other. I guess its not a V conf engine as its only a 1.6 zetec nothing fancy.
Old Jun 12, 2012 | 08:16 PM
Greasenuts's Avatar
Greasenuts
Hmmm, im not entirely sure what it is you can see then mate. Ill try to have a look at one when i have chance. (im a mechanic but not at a ford dealer so ill have to wait till i get one in). What year car is it?
Old Jun 12, 2012 | 09:18 PM
blader1611's Avatar
blader1611
I have a thread in the technical q&a thread with the 2 drc codes as the title. There are photos on there of what i am seeing. Still a bit unclear to be honest so i would very much value your input. Thanks
https://passionford.com/forum/techni...k2-2005-a.html
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
AJC
Oct 1, 2015 06:47 PM
Steve Escos
Oct 1, 2015 06:57 AM
