Ford Puma Discuss the Ford Puma here!
Help please, Keys lost for Puma
Old Jun 8, 2012 | 04:43 PM
flyingflynn's Avatar
flyingflynn
Default Help please, Keys lost for Puma
I wonder can anyone help here, I have a couple of Pumas in sweden www.icedrivesweden.com My pal there has lost the keys.....
So Uk local dealer needs cars so thats no hope
A guy in Denmark can drive over 1200 miles and reprogramme and cut keys for bothe cars but its £2000 which is more than they are worth.
However the cars are in great condition and do a brilliant job on the frozen lake, so is there another way round it
EG a breaking puma, would the key , ignition barrel and ECU do it, or do i need other parts, Is anyone breaking a 1700 both are 1999 models
Any advice would be gratefully received, Thanks Pat
Old Jun 8, 2012 | 04:53 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
yes those parts will fix it
if you want to be more violent you could get round it
Old Jun 8, 2012 | 09:20 PM
flyingflynn
Thats brilliant thanks, I guess I have to get the same year [1999] ecu, keys and ignition barrel [with coding ring],
I definitely wont need to code the car to anything else then??
As cars are in Sweden, I cannot get part numbers!!
Thanks Pat
Old Jun 10, 2012 | 09:27 PM
1.9 xr2 on 40's
st170 breaking
i think aslong as the speedo/odometer matches so digi or analoge
you can swap the ecu and key easily
im not sure the ring matters but if you like...
if it were me i'd get an ecu and key swap the ecu and use take a door lock out to have another key made from the locks code and use the new ecu's key as a fob/keyring just to work the immobiliser
its easy to have a key cut from any lock but its the coding that costs and sucks
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
