1995 Mustang GT (NEW 500 Horse Engine)
Old Jun 8, 2012 | 02:31 PM
ccnpassionford's Avatar
ccnpassionford
Platinum Sponsor
Exclamation 1995 Mustang GT (NEW 500 Horse Engine)
This listing is for a 1995 Mustang GT equipped it a Hawk 342 500 hp Engine.
This vehicle is in excelent condition and has always been garaged.
Engine Bay was painted black before new engine was installed.
Interior has been stripped with plans to install new carpet, rear seat delete kit.
Battery has been relocated to the trunk area in a stainless steel Steeda box.
Engine only has 150 miles on it. Reason for selling is I have started my own business and don't see this car getting finished.
Dash has 5 Auto Meter Gauges. Tachometer with Shift Light, Oil Pressure, Water Temp, Gas Gauge, Volts.
Has a Unfinished Cervini Hood.
Has the following on the engine:
Holley Systemax Intake 302 F.I.
Ford Motorsport Tall Aluminum Valve Covers
BBK Throttle Body
Motorsport 30lb Fuel Injectors
5140 Forged Steel H-Beam Rod - 3.400 stroke - 2.2486 Main - 2.132 rod
Manley 342 Flat Top
Akerly Y & Childs Xtreme Piston Rings 4.005 1/16 - 1/16 - 3/16
Clevite 302 Main Bearing
Clevite 302 Rod H Bearing
Melling High Volume 302 Oil Pump
Ford Motorsport 28 oz Balancer
C4/AOD Flexplate
ARP Ford CAM Bolt
ARP Balance Bolt
ARP 302 Hex Head Bolts
AMP Small Block Ford Billet TIming Set
Custom Ground Hydraulic Roller Camshaft
Motorsport 302/351 EFI Hydraulic Lifter
Ford Motorsport Hydraulic Roller Spider
AFR SBF 185cc Street Heads, 58cc Chamber
Scorpian 1.6 3/8 Roller Rocker
Other Items on Engine
Black Magic Fan Kit
MSD Billet EFI Dist. MSD Blaster Coil, MSD 6A Box, 9MM Wires
MAC Hi-Flow Cats System
MAC Shorty Headers
Walbro Fuel Pump 225lph
Aerospace Billet Water Pump
Motorsport Aluminum Driveshaft
Mac Cold Air Kit
McCleod Twin Disc Clutch - Flywheel 28oz
http://www.collectorcarnation.com/Mu...html?aid=32801
yorkie92
27
Sep 22, 2017 05:56 PM
3drRich
Sep 13, 2015 07:32 PM
1300gt
18
Sep 11, 2015 10:03 PM
ekjim
Aug 17, 2015 08:57 PM
rdvil
Aug 15, 2015 12:11 PM
