YB oil spray jets
Jun 8, 2012 | 09:12 AM
YB oil spray jets
What are the advantages over the conventional spray bar?
Jun 8, 2012 | 09:43 AM
Quote:
Originally Posted by
RWD_cossie_wil
you put oil under the pistons is better ..and you have a better colling also .
Jun 8, 2012 | 10:03 AM
as said more accurate oil spray to the little ends and piston to help cooling
Jun 8, 2012 | 10:15 AM
more oil more life to your engine ..in big specs better oil jets use
Jun 8, 2012 | 11:58 AM
Spray Jets =
Spray Bar =
Jun 9, 2012 | 12:20 PM
Has anybody got pics of the STD 4x4 setup and the best option available too? What mods are needed and how they fit too.
Jun 9, 2012 | 12:31 PM
Mr C
Depends what 4x4 you are talking about as the later Escos had them as standard I believe.
If its a non spray jet block then it would require machining into the oil gallery to fit the jets.
Jun 9, 2012 | 02:49 PM
polly_x
yes the last escorts small turbo they have oil jets...machining the block very expensive to an older block ....
Jun 9, 2012 | 02:50 PM
does anybody fits oil spray jets to a 205 block ?
Jun 9, 2012 | 02:51 PM
sierrafun
Its only approx Ł90-Ł100 for the machining then the cost of the jets but the st escos jets are still available ..
cheers danny
Jun 9, 2012 | 02:55 PM
750hp escos
cheers danny
only 100 pound .thats good ..i come there to make a block for jets
Jun 9, 2012 | 03:20 PM
is it thruth that the peugeot spray jets fit to the cossie ? they look like the same
Jun 9, 2012 | 03:59 PM
750hp escos
cheers danny
What oil pump do you run then, small turbo Escort?
Jun 9, 2012 | 04:01 PM
RWD_cossie_wil
these burtons sales high pressure
Jun 9, 2012 | 04:17 PM
You can run any oil pump and just block of un wanted holes or if your lucky enough to have an st esco oil pump even better..
Yes you can do oil jets to a 205 block
cheers danny
Jun 9, 2012 | 04:21 PM
750hp escos
cheers danny
cheers mate
Jun 9, 2012 | 05:14 PM
Just thinking for my next build, it might work out cost effective to go with the spray jets & small turbo pump rarther than pay for the 4x4 cosworth oil pump?
Jun 10, 2012 | 01:28 AM
RWD_cossie_wil
yea its more cost effective to run an uprated 2wd oil pump with the spray jets mate..
cheers danny
Jun 10, 2012 | 03:48 PM
you also get better oil pressure at tickover as the jets have built in pressure valves
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
rsguy
44
Sep 29, 2015 03:29 PM
