Emissions Fail on MOT
Hi Guys,
Just need a bit of advice as Massively failed on my emissions today, It is a '98 1.8 Escort GTi with a 2.0 Zetec engine. Results below:
Fast Idle:
CO 2.064% (upto 0.300%) Fail
HC 81ppm (Upto 200ppm) Pass
Lambda 0.949 (0.95-1.09) Fail
Secomd Fast Idle:
CO 2.371% Fail
HC 80ppm Pass
Lambda 0.940 Fail
Natural Idle
CO 0.367% (Upto 500%) Pass.
It was fine last year and the only difference is that it has had a new headgasket and now has a drilled airbox.
Any suggestions please help.
Fast Idle:
Secomd Fast Idle:
CO 2.371% Fail
HC 80ppm Pass
Lambda 0.940 Fail
Natural Idle
1.00 Lambda = 14.7 A/F ratio = Desired reading
0.97 (or less) - 1.00 Lambda reading = Rich
1.00 - 1.03 (or higher) Lambda reading = Lean
Can anyone clarify ?
Just done a bit of Googling
14.7 : 1 = Desired mixture (14.7 ltrs of air to 1 litre Fuel)
Lambda = 1.00 for desired mixture
So 14.7 x 1.00 = Desired mixture of 14.7
Lambda reading of 0.97 gives a mixture reading of 0.97 x 14.7 = 14.26 (14.26 litres of air to 1 litre of fuel) so a slightly richer mixture
Lambda of 1.10 - 1.10 x 14.7 = 16.7 (16.7 litres of air to 1 litre of fuel) Weak
Give it a good drive and check to see if you can smell the cat, when was your car services last dude,also just check your oil too incase your burning some too, normally I'f it rich the lamda reads low, sounds like it needs a good drive
You can buy pattern cats for £90 and the lambda should be no more than about £20/30 so try that first.
Could be anything that's caused it to fail,they dont last forever on some cars,particularly fords.
SMILER258
Sep 28, 2015 09:04 AM
