steering rack st170
Old Jun 2, 2012 | 04:56 PM
seddo's Avatar
seddo
Default steering rack st170
hi guys is it common for the steering rack to start knocking on these cars or is it just ford are crap? i had 3 focus's so far (1.8 zetec, 1.8tdi an st) and they all have had knocking steering racks. last ford im buying definately
Old Jun 3, 2012 | 07:53 PM
minder's Avatar
minder
i had a st 170 for 5 years and never had a problem with the rack now got a mk 1 rs and no rack problems with that either
Old Jun 8, 2012 | 02:18 PM
khanny1's Avatar
khanny1
i had mine 2 days and it started knocking.
Old Jun 9, 2012 | 12:01 AM
danme1987's Avatar
danme1987
when do you hear it knock?
Old Jun 9, 2012 | 07:58 AM
khanny1's Avatar
khanny1
ive changed it now but it was when started and just turn it slightly to the left you could feel it clunk like it was jumping a tooth or something, if you change yours and get stuck with owt just give me a shout .
Old Jul 19, 2012 | 07:43 PM
seddo's Avatar
seddo
If I'm at a standstill an move my steering left to right an vice versa it knocks pretty loud. It turns fine when I'm driving but over bumps it knocks bad an feel it through the wheel. Checked all bushes, droplinks etc an all seem fine
Old Jul 19, 2012 | 07:46 PM
khanny1's Avatar
khanny1
check the springs arnt snapped but it sounds like you rack like mine was
Old Jul 19, 2012 | 09:28 PM
seddo's Avatar
seddo
Going to check my springs again as it seems to bottom out over speed bumps an car seems pretty low for a standard rated spring.
Old Aug 1, 2012 | 08:40 PM
seddo's Avatar
seddo
i just done a search under steering wheel an checked the steering rod/shaft and can actually move it back an forward by hand maybe 3-5mm. it clunks when i move it. sound like new rack or is there a nut to tighten on the steering rack system?
Old Aug 23, 2012 | 09:17 PM
Takeshi's Avatar
Takeshi
Steering rack is fudged.
Old Mar 9, 2013 | 04:00 PM
simon_elvin's Avatar
simon_elvin
Can you use the rack off a different model or is it an st fit only? St racks are more difficult to find but have access to lots of 1.8 zetecs etc....
Old Mar 9, 2013 | 06:21 PM
khanny1's Avatar
khanny1
st racks are quick racks,
Old Mar 12, 2013 | 11:08 AM
borinous's Avatar
borinous
Balls sounds as though mine has the same problem
if im stationary and i turn the wheel slightly to the left then to the right i can feel/hear a clunk. if i do it in the other direction it doesnt do it.
Old Mar 12, 2013 | 11:13 AM
borinous's Avatar
borinous
could it be the inner tie rods??
Old Mar 12, 2013 | 11:40 AM
borinous's Avatar
borinous
https://passionford.com/forum/ford-f...ing-noise.html
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
