rear caliper hand brake lever
Old 02-06-2012, 03:32 PM
BRAMMER
BRAMMER's Avatar
Default rear caliper hand brake lever
In the process of rebuilding my rears and looking at the handbrake lever with the small bearing rod goes i can't work out if it's worn or as it should be
In the picture you can see where it's tapered then it drops down a little more
If anyone has rebuilt theirs did they notice the same thing?
Old 02-06-2012, 03:51 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
cant say i payed much notice but if it moves the piston as it should i wouldent worry! mine were badly pitted too so i filled the pits with chemical metal!
Old 02-06-2012, 04:32 PM
BRAMMER
BRAMMER's Avatar
I was hoping you replied mate as i noticed you have done yours before
I dummy built the caliper apart from the piston to make sure everything went together fine but when moving the lever it didn't move the threaded shaft - i wasn't sure if the caliper had to be completely built with piston to test that or not
Also what grease did you use? i was going to use Castrol rubber grease but thought i'd ask on here if their is anything else (should have got it before bank holiday which is why i'm looking for an alternative)
Chris
Old 02-06-2012, 04:36 PM
ajamesc
ajamesc's Avatar
I just used the normal daf spec wheel bearing grease we have in the work shop. And year maybe you have to put it all togther as it screws up the thread! Have you put the cir clips backin yet I did it with a socket and a g clamp the hole thing was easy
Old 02-06-2012, 06:04 PM
BRAMMER
BRAMMER's Avatar
I had a right good look at everything before i even dummy fitted it all - i changed all the seals ready in the main body of the caliper & piston - test fitted the cage that goes over the spring to make sure it will seat correctly which it wasn't so straightened the legs and fitted using my Halfords valve spring compressor with the small head on it and bent a mini pick to push the rear of the circlip down whilst the clip is compressed.
Fitting the hand break lever, bearing peg, spindle, washer, spring and clip takes no longer than 2 minutes but i tried the piston with a winding tool and it was very tight to the point i couldn't turn anymore and it still had about 2.5 full revolutions to do so was hoping you were going to say smear grease over the O ring and it goes in easy
If i can get that piston in easy then it's really a 5 minute job
Forgot to ask how much grease did you use around the hand brake shaft? and did you put grease anywhere else?
Old 06-06-2012, 10:44 PM
simonmcf
simonmcf's Avatar
Nightmare to get the circlips back in, once it's all clean and put back it should be fine, check your seals, moisture can also be absorbed by brake fluid
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
FlashRS
14-09-2015 12:36 PM
mint_s2
02-09-2015 08:58 AM
james kiely
28-08-2015 08:58 PM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: rear caliper hand brake lever
