Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus 1.6 zetec misfire, loss of power, CEL
Old Jun 2, 2012 | 02:31 PM
Andy_Viking's Avatar
Andy_Viking
Default Focus 1.6 zetec misfire, loss of power, CEL
HI,
Our focus has been running fine but has just developed a misfire/roughness and loss of power. It is drive-able but sounds rough and feels awful. Initially the Check Engine light was flashing, on 2 seconds approx / off 2 seconds approx, now it is permanently on.
I have checked for air leaks, loose connections, nothing appears loose or dropped off, plugs look fine and compression is good across all 4 cylinders.
Any ideas what I should be looking at next, any obvious suspect items which could casue this?
Many thanks,
Andy.
Old Jun 2, 2012 | 03:41 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
It could be the coil. I've changed them in every focus I've owned.
Old Jun 2, 2012 | 04:05 PM
Andy_Viking
I guess you can't test it?
I have seen warnings about using non-genuine ones but Ford ones seem to be over £100! Lot if it isn't the problem.
Some on the bay for about £30.......
Old Jun 2, 2012 | 04:09 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
I got a spurious one (cheapo one) and it failed. If your handy with a multimeter you could test the voltages across the terminals.
Old Jun 2, 2012 | 04:20 PM
Andy_Viking
Handy enough I reckon
Do you have any values?
Old Jun 2, 2012 | 05:22 PM
Andy_Viking
OKay, here is where I am, coil is the issue, I think:-
Resistance between 1 and 4 on coil pack is 10.45 kO
Resistance between 2 and 3 on coil pack is 10.32 kO
Seems okay..............
Leads are 1: 4.65kO, 2: 4.18kO, 3: 3.38kO and 4: 3.33 kO
But did a spark test on each tower from the coil, using same plug and lead:-
1 - Big Spark
2 - Very weak Spark
3 - Very weak Spark
4 - No spark
New coil required then?
Any outlets for a cheap OE one???
Thanks for help so far.
Old Jun 2, 2012 | 05:26 PM
martysmartie's Avatar
martysmartie
It should be easy to notice whether it's miss-firing or not.
A coil pack is two coils in a pack, each running two cylinders, so if one has gone then it will misfire on two cylinders 1 or 3 or 2 and 4.
Martin
Old Jun 2, 2012 | 05:29 PM
Andy_Viking
Martin
Hmmmm, that doesnt explain what I am seeing above, deffo big spark on 1, very weak on 2 and 3 and nothing on 4...............
Have repeated a few times now and get same every time????
Old Jun 3, 2012 | 04:30 AM
jimbone's Avatar
jimbone
Perhaps go scrappy get some ht leads? And have you tried new spark plugs seems obvious but just thought id put that out there lol
Old Jun 3, 2012 | 04:31 AM
jimbone's Avatar
jimbone
Actually ignore me didn't read your post properly
Old Jun 11, 2012 | 09:29 PM
Andy_Viking
New coil pack fitted at the weekend, got a Visteon one which I have read are the same as the Fomoco branded ones, works a treat and all is well
Here is where I got it from, really helpful chap:-
http://www.ebay.co.uk/itm/390379132068?ssPageName=STRK:MEWNX:IT&_trksid=p398 4.m1497.l2649
JoeyBoyden
Jan 4, 2024 02:36 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
