Caliper Carrier Bolt - Should I Get Them From Ford?
Hi all,
I was changing the discs and pads and a rear caliper on my ST170 yesterday. Got to the last corner, the one needing the new caliper and rounded a bolt on the carrier.
Was just wondering if this is something that I should get from Ford (bit of a trek for me) or if I could go elsewhere and get it matched as long as it's hard enough? I'm thinking I'll just go to Ford, but it'll no doubt be extortionate.
Cheers,
Alan
Cheers,
Alan
Don't ask - I don't know
If not:
Cut two flats on it so you can get an adjustable spanner onto it.
Use lots of heat on the carrier.
Of that fails then you will need to drill it out.
Can't multiquote on my phone, but cheers for both the suggestions.
Mr S1 - have tried that already to no avail. Guess I could try and file it a bit, as it's currently a bit big for the next socket down, even with a hammer. Also quite tricky to get access.
Will - might try cutting to flats on it. Another idea was to weld a nut on to it? That seems like quite an easy option, and I know plenty of people who weld.
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
