Anyone else have this happen when cornering hard left?
The three bolts that hold the pulley on hit the wing! lol
There's probably about 10-20mm clearance at a complete guess (should really of taken a pic) and the engine and gearbox mounts were all fine at the time of fitting (month or so ago).
thats weak old mk4 shells flexing for ya lol, my mates old 16i with a t4 (yes t4 lol) on a cvh used to flex that bad the front wings rubbed the paint off the a pillars were they meet the windscreen!!
Can yon not just slacken the engine mount, bar the engine over a little bit more then lock the engine mount up again?
That could work if you have enough play in the gearbox mounts. Works fine on a ka too.
I took the bolts out one at a time and used my hand lathe (grinder lol.)
Interested as i've modified mine to use the blacktop/duractec mount on the end of the engine. Hopefully theres no movement in it but nows the time to check before i'm done with the fabrication!
Hopefully mine will be right then. Though might be worth clearancing my inner wing now while I've got the chance since I'm doing it for blacktop aux belt setup anyway.
