Mondeo 52reg TDCI estate Wishbone/ball joint
I got to change the front ball joint on 1 side of the car, but will do both as i was kindly given the pair when i bought the car
Thing is these are the bolt on one, i have never fitted these before, i have always had full wishbones and replaced in one unit.
How easy is it to change just the ball joint part? how much should i pay to have it changed? Will it need Laser/wheel alliment after?
And one last question, can you get wishbone poly bushes for the estate tdci mondeo`s? as thinking maybe poly bush an old set of nackered wishbones and fit the new ball joint onto them.
Hi fella -
Grind the old ones off and bolt the new ones in, it's pretty straightforward and I'd imagine a garage would charge for no more than a couple of hours labour. Would be worth getting the alignmenbt done just be on the safe side.
Powerflex do wishbone bushes...
http://www.powerflex.co.uk/product-d...Bush/1711.html
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
The Enigma
Sep 29, 2015 10:31 AM
