Focus rs mrk 1 huge spec!!!!!!!!
NOT SURE IF I'M DOING THE RIGHT THING HERE BUT HEY LETS SEE HOW IT GOES..
HERE I HAVE MY MUCH BELOVED MRK 1 FOCUS RS ON 52 PLATE 2003 MODEL.57K THE CAR COMES WITH FULL SERVICE HISTORY LONG MOT AND TAX SURE IM THE 5TH OWNER (NEED TO DOUBLE CHECK ON THAT THO??)AND HUGE FOLDER OF RECIEPTS TO PROVE ALL THE WORK CARRIED OUT ON THE CAR (MODDED AND STANDARD PARTS) THE CAR HAS ONLY DONE 7000 MILE SINCE FULL ENGINE REBUILD.
QUICK SPEC:
eagle rods
je pistons
ford racing cnc machined big valve head
ford racing inlet
ford racing 70mm throttle body
newman cams
un-locked standard ecu with custom AET remap
heat wrapped dei titanium manifold (no sure the make yet?)
light weight adjustable pulleys
arp bolts used
racing concept inlet manifold (puma speed)
full stainless steel miltek system
denso itv z7 plugs
msd coil pack and leads
turbo smart dump valve
garrett gt30,71r turbo
ap 6 paddle clutch kit (new slave cylinder)
45mm airtec radiator (brand new)
100mm airtec intercooler
bosch group a 044 fuel pump
forge swirl pot
sytec fuel filter
turbo smart fuel regulator
rc 650cc injectors
uprated engine mounts
baileys header tank and power steering tank
spec r oil swirl poy
all ss fuel lines
auto specialist dip stick tube and head, ht lead cover,injector rail cover
coil pack bracket and engine heat sheld.
ggr carbon effect cam cover
turbo smart boost controller
samco hose and roose motor sport hoses used through out build
ebc ultramaxx discs front and rear drilled and grooved
ds3000 pads front and rear
creative carbon front splitter
new steering wheel
spa boost and water temp gauge
wide band 11 air fuel gauge
dynojet
standard rs sparco seats and rs floor mats
sony head unit
fly 12" sub amp and speakers
4 new toyo proxies t1rs on standard oz 18" matte black alloys.
The car is built to run at 500+ bhp with no problems but due to still running on standard management and rc660 injectors its sitting at a impressive 398bhp @19psi.With rc 750 injectors and standalone management i.e gotech,halitech and autotronic ect ect its more than capable to run 500+bhp
i might have forgot some stuff if i remember il add in listing if you have any questions please just ask by pm text or phone call on 07955900207
£9995 ono
QUICK SPEC:
eagle rods
je pistons
ford racing inlet
newman cams
arp bolts used
denso itv z7 plugs
forge swirl pot
sytec fuel filter
rc 650cc injectors
all ss fuel lines
new steering wheel
dynojet
sony head unit
£9995 ono
Can't believe you're thinking about getting rid buddy.
But it's got a serious spec and big potential for more too... so sure if someone serious came to view it then it'd sell no problem.
Cheers,
Grant
Cheers,
Grant
absolute cracker of a motor Paul, would make one hell of a track car that mate
definately my next purchase is one of these cars probably next year now , with as close to that spec as possible
Will pass on the info anyway. Cheers
