how can i tell what map sensor i got
what can tell me if i have a standard map sensor or 3bar? Its only stage 1 but would still like to check as boost is now about 15psi
It should be mounted to the inner wing. To the left of the header tank, upside down. 3 x 10mm bolts hold it in. I'd say yes to see part number. But if you know who's chip it is. Just give them a shout and ask if they fit a 3 bar. I very much doubt it.
95% sure it'll be standard
This sounds dangerous!
I assume your boost has been adjusted?
If so then there is far more involved than just changing the MAP sensor, namely a remap and injector changes etc.
Going by what you have said you may be heading for an engine meltdown!
Martin
Martin
hi martin. I put a post up about it a while ago which u commented on. There was no pre load on actuator and i was down on power. Just need a new chip to take into abount voltage chance between standard map and 3 bar one iirc. Injector are still within safe limits
Oh right, tbh it's going to be more a custom chip as typical stage 1 uses standard hardware.
Yes different map sensors have completely different scales so you would need a chip calibrated for it as such AND for the amount of boost you are running.
Martin
Martin
are 4x4 and 2wd map sensors different? i've read the wiring is different as the 2 end pins are the other way round? if thats the case can i swap them round and use a 2wd map sensor on a 4wd?
cheers
cheers
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
