idling on a 3dr cosworth
From cold the idle is up & down now ive changed iscv & the map sensor & it's still does it but it stops doing it when it's warmed up
I have always had this problem, it could be a few things.
I suspect it's your TPS at fault, in your case you can unplug it, as a test, and see if this makes any difference, if so then you need to look at calibrating the TPS etc.
When you say you changed the ISCV, I suspect this will be a pattern one off the bay etc?
If so these arn't that good, I have one myself and whilst it got rid of my hunting problem it run very fast with it, so much so I reverted again.
The reason being is the incorrect springs being used, you can get them to work but they need a lot of playing around with, I have to do this with mine.
Martin
Martin
3dr cossie
21
20-11-2015 05:00 PM
