Heater
Old May 28, 2012 | 01:09 AM
kamylamy's Avatar
kamylamy
Default Heater
The heater control on my series 2 is turning towards cold and not hot what could be the problem? Any suggestions are appreciated............
Old May 28, 2012 | 09:01 AM
beaver rs 88's Avatar
beaver rs 88
in the garage
Knackered cables to the heater box
Old May 28, 2012 | 09:08 AM
s2turbsZVH's Avatar
s2turbsZVH
Will it ever end !!!!!!!
Also if you are trying to say that when you turn to hot its still cold then is probably the Thermostat.
Old May 29, 2012 | 01:46 AM
kamylamy's Avatar
kamylamy
I said I can not turn the knob to warm it just won't turn. Thanks
Old May 29, 2012 | 05:44 AM
foreverford255's Avatar
foreverford255
It may need the cable adjusted bud,iirc its the cable on the right hand side in drivers footwell
Old May 29, 2012 | 10:00 AM
kamylamy's Avatar
kamylamy
You mite be right cod dash has come out a few times including clutch rachet change
Old May 29, 2012 | 10:38 AM
foreverford255
Youll probably find the outer cable is moving instead of the inner there should be a metal clip that holds it which fastens to the lower dash support
Chas
Oct 5, 2015 07:13 PM
Flatlinedan
Sep 18, 2015 12:41 PM
K42L
Aug 28, 2015 01:23 PM
