Diff mount all fitted
Well after some messing about with the bolts i fitted the new diff mount i got from msd, took the car out after just to make sure it was all ok
From getting in the car it felt higher at the back and alot more SOLID, got a few miles down the road and i must say its makes such i differnce to the feel of the whole car . A must have /fit for £120
Next up is to get some new springs ,as mine look like they have sat on the bottom of a river for 26 years and why i was under the car i noticed my rear anti roll bar bushes are falling apart so i will get both items during the week ready for next weekend.
But all in all im happy
I fitted mine and put MSD's engine mounts...lowered the car 20mm on Ahmed bajoo springs and fitted camber shims and poly bushed the 3dr and it feels fucking brilliant on the road... The diff mount makes a proper difference..!!
I think i have to get back under the car and adjust it as the washer the sits between the mount and the diff has a 3mm gap and it dont look right , maybe i didnt cut the bolts short enough , so ive gone and got 6cm 7cm and 8cm to see which ones fit best .
Not a dig but maybe it may be worth looking at the bolts you supply for ones that are the right length it would say a bit of messing about .
But again a nice item for £120
So ive had this fitted a few weeks now, but feeling a vibration through the gear stick and back end ?is this normal as the mount is more solid etc ,im also get a slight clonk - knocking from the passenger rear side? thinking anti roll bar bushes ?
As I said above I fitted Diff, Gearbox & engine mounts & have not really noticed any increase in noise or vibration, but needed to replace the diff mount top bolt to a countersunk bolt to clear the ARB,
You might be getting the noise/vibration from the bolt hitting the ARB whilst driving.
fitted mine afew weeks ago,must say its massive.i to have a vibration iam thinking it could be my drive shaft a knock on effect of every thing being so solid with the new mount.
After having mine fitted it made the car feel more sat up and once the power is applied it all feels like its going into the road. My saph felt soooo vague before this upgrade. Must get them countersunk bolts too.
I've just bought one of these mounts,waiting on delivery now.I had an MCR diff mount which I purchased brand new for my old 3dr and never had a problem with vibration,I hope the msd one is the same fingers crossed.
Thanks.Lee.
Thanks.Lee.
Yes you do,i was out in the cossie today again and theres alot more vibration, and a knocking . but once new bushes are fitted etc i hope it cure's it .
Guess you 2 have better bushes fitted or your standard ones are still ok ?? I think as the diff has lifted about 2 inches now i need to also change gearbox mounts, as with most mods ,you change one thing and end up having to change a few other items too........
I was advised that if you go down the uprated Gearbox mount route you should also do the engine mounts at the same time so they have the similar flexibility/strength
Oct 9, 2015 07:38 PM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
xr4x4rs
Aug 6, 2015 09:03 PM
