sapp cos non starter
hi guys anyone have any idea were the ignition relay is located on a non lambda 4x4 sapp cos as i have no supply to the ecu [l8] when turning on the ignition also pins 1 and 19 should be earthed but show 12v when ignition on hhheeeeellllllpppppppp
revisiting the dark side
Just an addition.......... does anyone have any schematics for the wiring on the ecu and engine bay wiring?
I'm fairly sure that it's an earthing issue after an engine swap...... I've read somewhere that pins 1 & 19 on the ecu should be connected to an earthing point on the block?
