Timing belt removed, crankshaft pulley at 16
Old May 27, 2012 | 09:34 AM
Mathias's Avatar
Mathias
Default Timing belt removed, crankshaft pulley at 16
Hi,
wanted to know what happens when the engine is not set at TDC.
Removed the timing belt from the RS Turbo (S2) and the engine was set with the pulley notch at 16 and not TDC (0).
Means this that the ignition was retarded?
Thank you for your help!
Old May 27, 2012 | 10:31 AM
haz87's Avatar
haz87
No it means your cam was massively advanced (or ground really really really badly )
Suprised you didnt clip a valve
Old May 27, 2012 | 10:40 AM
Mathias's Avatar
Mathias
Engine has been dismantled and looks very good (just 60.000 km on it), but I will have again
a detailed look on the valves and pistons.
Cam advance means more power low down and less high up, right?
Old May 27, 2012 | 12:42 PM
mgtkr1's Avatar
mgtkr1
means it will be perky off boost but will cause carnage on boost. such as detonation,(=melted pistons) and valve/piston contact.. id either check the cam profile/spec and be absolutly sure it was timed up right. or play it safe and run it as per factory. and set it up at a tuning centre. how did the car perform before?
Old May 27, 2012 | 05:17 PM
Mathias's Avatar
Mathias
please tell me what perky and carnage means, never heard this two words
Engine was running let´s say normal but not powerfull.
Turbo just made 5psi boost.
Except the crank it was timed up correct. All parts (pistons, block, valves,...) look very good.
When the engine will be put together again, it will be adjusted to TDC as it should.
Just wanted to know why the pre owner adjusted the crank to 16 and what is
the difference to the TDC adjustment. Was not sure if there are just changes to the
cam or if also the ignition will be influenced.
Old May 27, 2012 | 05:24 PM
mgtkr1's Avatar
mgtkr1
is it not possible the belt has been jumping which is why its at 16deg insteast of TDC. by perky i mean responsive. by carnarge i mean serious engine failiure. not good. set it up as per manual and have it checked over
RUBY123
Oct 22, 2023 12:04 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
cameron2
Aug 25, 2015 07:18 AM
borboyous
Aug 22, 2015 11:17 AM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
