Ford Range This section is for other models in the Ford range.
Cougar v6 coolant problem after driving
Old May 26, 2012 | 09:50 AM
Leeproc's Avatar
Leeproc
V6 Cougar 2
Default Cougar v6 coolant problem after driving
Hi, everytime i drive the car, after a few days the coolant light comes on and i have to put some coolant in it, it doesnt leak alot but its annoying when it comes on when your ready to set off for work. I had it in 2 garages and both said they cant find a leak but there is a small puddle under the car sometimes and im pretty sure its coming from the thermostat area.
Anyway i stored the car for a few months and it didnt leak anything while stood, i got it out again yesturday and drove it and it leaked a bit again. I think a pipe must be expanding when the engine is hot maybe?
Can anyone recommend something i could put in the tank to seal the leak for a few days untill i can get it back in a garage, after paying for a rip off tax disc, re insuring it and petrol im skint.
Old May 26, 2012 | 01:42 PM
Leeproc's Avatar
Leeproc
V6 Cougar 2
Has anyone had this problem before? I have just been out in it and then checked for a leak, cant find one, its doing my head in!!
Old May 26, 2012 | 06:01 PM
Chaz888's Avatar
Chaz888
I have the v6 there is a known problem with the tank sender it will say its low when in fact its fine with mine I just had to clean it , the little leak could be moisture off the AC unit parts maybe , but give it a look over from underneath you may see a weep from a hose union .
RB26DETT
Oct 25, 2015 05:41 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
RB26DETT
Ford Mondeo Including ST
Aug 28, 2015 01:56 PM
muffster
Aug 17, 2015 08:17 PM
