909 4x4 box questions
Ok, the 909 box, if I was to take one and try to fit it to a road car, what else would I need, are the props, mounts, flywheel/clutch the same as a STD cossie?
Which uprated box is best for say roughly £3k, Bara, Dome, Quaife, Fixit, Oppliger, 909, or any others I should be thinking of?
I was getting all embroiled in the noise and ratio issue but now I'm thinking screw it, just get the best box for my budget.
I am sure for some 909 boxs you need both props ......ffd boxs.....
Been a while since i looked into them .
I use a shootpeened and polished gearkit in my 4x4 only time will tell how my torque it will take.
