Door leak
Old May 23, 2012 | 11:00 PM
kamylamy's Avatar
kamylamy
Default Door leak
Hi I have a major problem if anyone can help? Right here I go well basically I have a door leak on my rst series 2 it's really annoying and I'm fed up. It's not the roof it's not the seal cos wen I change it over from the pass side still leaks had a work done on the car and after that it happens tried adjusting door countless times with hinge. The only thing I can think of now is that the door is not close enough to the black strip that goes on top of door, does it need bending in? And it's not a cabby
Vacuman
Sep 22, 2015 12:09 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
Vincereese
Sep 18, 2015 12:48 PM
talon1
Sep 15, 2015 10:27 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
